It is currently Wed Jul 30, 2025 5:33 pm
PostPosted: Mon Feb 10, 2020 12:09 pm
First name: Justin
Last Name: Eisenman
City: Asheville
Zip/Postal Code: 28806
Hi all, I have a guitar here with some interesting checking that isn't visible when looking straight on. . It is the target water-based lacquer. I know what causes nitrocellulose to check, but this looks slightly different. The guitar is just under two years old. Has anybody had this experience with Target EM6000?
PostPosted: Mon Feb 10, 2020 12:16 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I've finished twelve guitars with EM6000 and haven't seen checking. On your guitar, is the EM6000 applied directly to the wood?
PostPosted: Mon Feb 10, 2020 12:22 pm
First name: Justin
Last Name: Eisenman
City: Asheville
I used their sanding sealer as a color coat. Side note, I talked to the guy at Target last year who told me I could skip the sealer. Thanks for your reply.
PostPosted: Mon Feb 10, 2020 12:34 pm
First name: Jay
City: Bothell
State: Washington
I've done the same using their sanding sealer as a color coat on some guitars without problems so it's probably not due to that.
PostPosted: Mon Feb 10, 2020 12:48 pm
First name: Justin
Last Name: Eisenman
City: Asheville
Rocher, what is your Sanding process?
PostPosted: Mon Feb 10, 2020 12:59 pm
First name: Jay
City: Bothell
State: Washington
For final sanding and polishing of the finish, I've been level sanding dry with 400 grit and, since I didn't have a buffer until just recently, I've been wet sanding with Micro Mesh pads 1800 through 12,000 followed by LMI's cut polish and Meguiar's Mirror Glaze #17. It's tedious, but it gives pretty good results.
PostPosted: Tue Feb 11, 2020 7:06 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
What exactly was in the "color coat"? Dyes, colorants etc can have drastic effects of film flexibility.
Brian
PostPosted: Tue Feb 11, 2020 1:59 pm
First name: Jay
City: Bothell
State: Washington
Brian's question reminds me that Target Coatings sells two sealers: EM1000 WB Universal Sanding Sealer and EMTECH USH3000 UltraSeal-WB Shellac Sealer. Which one did you use?
PostPosted: Sun Feb 16, 2020 7:16 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I’ve been using it since it was called PSL. I’ve never seen anything like that. One of the reasons I like EM6000 is that it won’t check. I did have a problem a few years ago when I tried the Target high build lacquer, I think it was EM7000, as a base coat (to help fill pores) followed by a top coat of EM6000–that crazed and had to be removed. I use flake shellac dissolved in Everclear as a sealer and base coat. If you figure this out, please post the results. We need to know.
Users browsing this forum: JimWomack, Ken Lewis and 20 guests
